Sensor help ?
kmhm97
Southern Illinois
5.2 L V8
An animal has chewed through the wiring at several sensors on my 1999 Dodge Ram 1500. Looking for help on how to fix this. Would I need to purchase a whole new wiring harness? any help would be appreciated!!
NoMPG2010
If it was me. I would go to the nearest you pull junkyard and start getting the wiring you need.
SYKRAMMAN
Banned
Jersey shore
06 Mega
Yeah junkyard is the place, I would clean those leaves out, they can cause issues.
Oliver
5,2 V8
it is possible to order the spare connector @ rock's website ;-)
at least for the trottle position sensor. It's the most simple for sure
K
kmhm97
Southern Illinois
5.2 L V8
So I found the throttle body sensor on RockAuto's website. What do you call the other two sensors called?
Thank You all!!
Gr8bawana
6.7 CTD
The other 2 are not sensors they are injectors. You need just the connector that goes onto the injector.
