Service 4WD, ABS and traction control light issue
JJP71584
Pgh, PA
These lights popped up on my dash and a few times my brakes were engaging ABS at low speeds. Found a video online and took a chance to correct it and it worked. Total cost was about $40, definitely recommend changing both at the same time.
Here's the video I referenced.
Take your time pulling the sensors out as the first one snapped and I had to drill it out. Took less than an hour and only needed an 8mm socket, a flathead screwdriver and a large pair of vice grips.
Hope this helps.
muddy12
Indiana
Hope you are lucky enough that your issue is actually one of those sensors.
I have a 2012, and have been dealing with the same ABS, traction control, and Servive 4x4 lights for quite some time now.
The short version of the story is;
I now have new speed sensors at all 4 corners, as well as new front wheel bearings, and those lights are still randomly coming on.
Turns out my issue is somewhere in the wiring between my right rear sensor, and the ABS module.
Oh, and just FYI, if you have the 44-44 case, even though the 4x4 light still comes on, you will not get any power to the front wheels.
CVX20
Ont,Ca.
2019 Classic Express
Have you checked that large plug in behind the left front fender lining for corrosion?My buddy was a shop foreman and when I bought my 15 SLT new he advised me open that plug and fill with dielectric grease.He told me it was the cause of ABS and 4X4 issues.It hangs pretty much out in the open and is easily seen just laying beside the truck.Worth a shot.
muddy12
Indiana
Didn’t know that was an issue, but will be checking it shortly.
Thanks for the info!!!
B4DR4M
I’m currently running into a similar issue except my truck won’t run lol it’ll crank just fine
muddy12
Indiana
Just checked that plug.
LOL at whoever thought that was a good location for an electrical plug :wtf: .
A word of caution though, especially if your truck has some age on it, the little locking ears are brittle!!! Just releasing the locking lever caused one of the tabs to break off on mine. Hoping just one will hold it together, otherwise I’ll have to figure out some way to put a zip-tie around it.
B4DR4M
LOL at whoever thought that was a good location for an electrical plug [emoji2357].
Has that seemed to solved your issue?
muddy12
Indiana
Too soon to tell for sure. My issue has been totally random. The only thing consistent about it is that the code that comes up is always for the right rear wheel speed sensor. Some days the lights will come on after only moving a few feet. Other days, like last week for example, I was able to make the 100 mile round trip to the feed store, without any issues at all.
B4DR4M
Definitely keep me updated. I
plan on checking mine as well but got to get down to the asd relay for mine.
CVX20
Ont,Ca.
Did you see any obvious corrosion or evidence or water intrusion?
muddy12
Indiana
No obvious signs of water. However, there was a lot of really fine dust, which I assume is due to living on a gravel road. I blew it out with compressed air and put it back together. I didn’t have much dielectric grease though, so I need to pick up some more, and add a little more to the plug.
CVX20
Ont,Ca.
Fine dust from salt spray maybe.That **** gets everywhere and salt is an awesome conductor.We used to make up a salt and water solution to check intermittent wheel speed sensors.
Harleyhog
Canada
Did u figure what your trouble was with your abs light I have same problem
muddy12
Indiana
I guess this can be considered an update.
My issue has not been resolved.
All three lights will still come on randomly, and each time, the code is for erratic performance of the right rear wheel speed sensor.
I have not yet had time to physically check all of the wiring between the ABS module, and the rear axle, so for now, I’m just resetting/clearing the code, whenever the lights come on.
Nrich902
Nova Scotia
Does anyone have any suggestions for me. I've been dealing with the traction control, ABS, and service 4 wheel drive lights for over a year now. anytime I get a mechanic to scan the codes, it just comes up as a wheel sensor, they've all been changed along with 3 of the 4 wheel bearings, but the lights do not go away. when i switch to 4 wheel dr it says it switches to 4 auto and 4 lock, but not 4 low.
Nrich902
Nova Scotia
were any of these issues resolved? Did you end up finding anything other than the ABS sensor or wheel hub? could it be the ABS module?
am3334
