heckcat9
Couldn't find a definitive answer in previous threads so I'm bombarding you all with some questions now.
How does setting tire size with AlphaOBD work when an Edge Pulsar is installed? Should I set the tires using AlphaOBD and leave the Pulsar be?
The Pulsar is basically a man in the middle attack between my PCM and the truck, yeah? If I change the tire size in AlphaOBD, will the Pulsar see that change?
Thanks
Thanks
