shaking!!!
Earls5.9
5.9 Magnum
Just had the trans rebuilt but I am getting shaking/vibration at 45mph. Anyone else had this happen. '95 1500 5.9 2wd. Thanks for any info.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I too, have a bounce and shake between 40-55 mph. Never been able to pin it down.
Verify that your tire balance is good and that you don't actually have a misfire at that speed by pressure the OD OFF button to turn that off. That will pick the RPMs up and take it out of the bounce-range.
jadocs
Are your trucks lifted?
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
My truck is stock, I can't speak for the OP though.
dapepper9
Iowa/Nebraska Border
5.9L V8
Need more info. Is it coming from the front end? Rear? Center of the vehicle? Change if pressing the gas?
E
Earls5.9
5.9 Magnum
Center/rear. 2wd stock susp. If you stomp it it goes away
Merc225hp
NA
truck
gas
Time for a compression test and a spark test.
E
Earls5.9
5.9 Magnum
The od trick worked! So time for a tune up I guess??
lone12star
Kyle, Tx
Does your drive shaft still have the weights on it?
Sent from my HTC One_M8 using Tapatalk
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
There is a Dodge technical service bulletin for spark plug wire routing.
I'm not on my normal computer so I can't link you, but you can find it on Dodgeram.org in the tech section.
