Mohpar
So I finally started the shift kit. Dropped the pan, took off the valve body, and used the TransGo TFOD-HD2 to modify the valve body. It also came with springs for the rear bands and front (bands?) that I haven't installed. I'm fairly certain you have to drop the trans to get them in.
Anyhow. Truck is shifting oddly. Acts like it's slipping into neutral when I stop, and sometimes on the highway when cruising. I can't get past 4k RPMs and it shifts oddly on the highway, I had to turn OD off and cruise at 3k. At stoplights when I go it takes a half second to engage and shifts (nice and) hard into gear, but at higher RPM the it shifts softer than before.
When I park the truck for a few minutes and turn it back on, it won't even engage for about a minute. I think it's a problem with not getting enough pressure, something that the springs I haven't installed could be the cause of. I didn't change anything else, new filter, didn't adjust bands or anything.
Transmission junkies, where are ya ?
Last note - I'm about to start school again. Thinking of grabbing a stock valve body out of a parts truck for the time being.
