Thanks - will go research differences. Been using HD exclusively, but I have HD truck and Class 4 RV, so not same as on LD trucks and cars.
OK - Bilstein website not very helpful, no compare data. 4600 (HD) targeted to trucks on or off road, no lifts. 5100 targeted to off road and lifts.
I guess that means 5100 is damped softer, but there's no data or descriptions of ride. My 2500 came with off road package and 4600, which is also what I have on RV. The higher damping rate handles rolling dips better, but are very harsh over rocks and potholes.
If 5100 is softer, then that explains why they soak up harsh road conditions - rocks and potholes, but would wallow over rolling dips. when Bilstein talks about "improved control" or "sporty handling", they mean higher damping rate. Which was esp. useful in the RV - no longer wallows side to side or over dips.
My HD truck on the other hand, can knock yer teeth out over potholes unloaded with tires aired up fully (like Feds make OEM software do). I could upfit with controlled airbags, but lotsa moola and time to do it right w/o winter moisture freezeup.
