shocks and level kit
02ram47
Bethel, Me
4.7 magnum
I was wondering what level kit I can run on my 2016 Laramie Power Wagon. I have been doing some research but can't find a solid direction. I have a decent amount of rake on my truck and would like to make it look better. I plan on running 35 12.50 17 on it. the rear wont need any lift. I am also looking for the right shocks as well. Are the factory Bilstiens the best for these?
Nick@GotExhaust
Supporting Vendor
SC
You could do the ICON front coils and shocks. That will provide 2.5" of front lift and provide better performance as well. Message me if you would like a quote or if you are interested in other options
olyelr
Kewadin MI
2.5” on a pw?! Thats too much without doing the rear too.
buckeyexx
Ohio
2016 Power Wagon
Thuren 1.5” with shocks is a good choice. That’s what I’m running on mine. If you have a 3” rake then you must have something in the rear already because 1.5 will level you out if stock. Might want to look above your rear springs and see if you have blocks above them. That’s the only way you’re going to have 3” of difference front to back. Or you have longer springs
olyelr
Kewadin MI
I have about 3” diff front to rear on my PW. I was looking at the Thuren 1.5”. Any thoughts
Yea what buckeyexx said…3” rake is way more than normal on a power wagon. Usually the thuren 1.5” springs will level it out very well…or almost make it look like the ass is low.
62Blazer
Midwest
I have the Thuren 1.5" front coils on my '16. After installing a heavier ARE bed cap (had contractor boxes inside the flip up side windows) I wound up putting 1" spacers on the rear to level it. In any case, 1.5" in the front should be plenty to level it out and would think any more would be too much.
Most people tend to be on the Thuren or Carli bandwagon on this page and say you have to spend $600+ for a level and shocks or you will "ruin" a Power Wagon. Granted, I have Thuren front springs and shocks but don't think a typical small coils spacer would cause any issues. There are several people who run leveling spacers on the front of a PW with no issues, but you don't hear from them on this page because they get beat up about it.
buckeyexx
Ohio
2016 Power Wagon
I agree. You could by with a spacer without issue. I did that on my last 2500 and never had an issue with it. I was going to go with a proryde kit on this one but decided to go Thuren for the better ride with the springs and shocks. The proryde kit is adjustable from 1.5-2.5” and seems to be well made.
crazy jerry
WY
pw dont have 3" rake. its only about 2". leave the springs alone if you tow or haul anything as even a few hundreds pounds starts to compress the rear and youll be sagging badly. or add a 1" spacer to the rear with thuren front coils
slingblade
Southern California
When I purchased my '16, it had a spacer for the factory springs and the shocks. The ride was alright; Thuren's springs and Bilstein shocks made a huge difference. I'm unsure how it works, but the King stabilizer is just as advertised. The truck came with 35s, and I recently purchased a new set and no rubbing with the spacers or the springs.
22hemi13
Tucson AZ
2014 2500 4x4
Rear spacer no issues. Thuren sells a rear spacer. The front spacers “work” they are just not great. Thuren is not a lift kit. It’s a suspension. Once you have tuned suspensions you’ll never want stock stuff again. Even stock pw leaves a lot of performance on the table when it comes to stock suspension.
buckeyexx
Ohio
2016 Power Wagon
This what it looks like with Thuren front 1.5 fox front kit and 1” spacer in the stock rear coils on fox 2.0 shocks.
sduncan86
Bakersfield,Ca
I have a 22 PW, but you should get the same result. I did the Thuren 1.5 level kit with the fox 2.0 shocks and their track bar. When finished and after driving, the front sat 1/4 in lower than the rear. The rear is factory. I added 37s and have the slightest bit of rub on the rear of the front fender well. I used Raceline Monster beadlocks 17x8.5 with +12 offset. For your 35s, I’d go with the Thuren kit and Fox shocks. If you need to haul heavy and are worried about rear sag, add the airbags and the lower cradles.
2Tallguy
San Diego
5.9 diesel
Thuren soft 2" coils and their tuned Fox shocks. Give them a call and discuss it with them. Top notch engineering and production quality.
62Blazer
Midwest
To be perfectly honest, I was disappointed after installing the front Thuren coils and Fox 2.0 shocks. Not because they are bad, just that they didn't really make a noticeable difference driving down the road. Think I was just expecting too much because of all the hype it gets. After some more seat time I do think it rides and handles better at higher speeds off-road, but unfortunately that is a very small percent of the miles it gets.
As comment from a different post, the Thuren front coils are actually stiffer on a PW versus the stock ones. It states that right on the Thuren website.
22hemi13
Tucson AZ
2014 2500 4x4
I dunno. Mine had the predator kit and 3.0 all the way around. It’s smooth and comfy on road or dirt. But shines in the dirt. I think people put this stuff on forgetting that it’s still a 1ton truck and heavy. “Soft” ride is subjective. I don’t want a soft ride. I want a tuned ride.
DripJust
Canada Ontario
Anyone know if I could use the front springs from a 2500 on the 1500 strut as coilovers ? I already have the HD springs in my rear and it gave an added lift with billet 2" spacers.
I was thinking of do the same in the front and adding a tophat 2" spacer .
olyelr
Kewadin MI
No they wont.
And dont even think about doing a spacer on the strut.
Immerge
