Should I Add The OEM Trailer Braking Module And Get Alfa OBD, Or Go 3rd-Party?
saboken
If you go with a Tekonsha controller be careful of the connection on the unit . Mine started to act strange on my other Vehicle, what happened is the solder joints inside broke loose from removing and replacing it when not needed. Other than that it works great. I don't know about using the existing harness on Ram?
09SilverRam
The South
The OEM is the only way to go. Any of the others will keep hitting your knee. Easy to install too.
You can get aftermarket with a hidden firm factor. This is the one I have but there are others :
I mounted the button where my drivers side 12v outlet was.
09SilverRam
The South
there are 2 types of Class 3 Hitch Receivers
Frame mounted & Sub Frame mounted
Sub Frame mounted only Class 3
Frame Mounted Class 3
This one is bolted to the trucks main frame rails & the sub frame too
Class 4 is also Frame mounted, just heavier duty
The subframe connected class three works well for 600 / 6000 tongue / trailer which is what they are rated for without WDH. I wouldn’t use them for more, if you are going to use a WDH I would get the frame mounted.
Random_Walk
Random_Walk
...what's this bolt do? *plink* ...oh.
Out
2017 QC 4WD SLT
Pentastar 3.6
I am very happy to report that 1. No WDH was needed (it hadn't come in yet), and 2. In spite of 30 miles of typically brutal (and sometimes bouncy, and in places poorly maintained) mountain roads taken to get home, the trailer pulled nice and easy, with no sway at all. The Tekonsha unit worked flawlessly; I started at 5.5, bumped it a couple notches up after a stop on the way home, and no worries there. Temps were well within range; outside air temp was 45 degrees or so.
Thank you all for the advice!
Random_Walk
Random_Walk
Out
2017 QC 4WD SLT
Pentastar 3.6
PS: The result (stopped at Walmart on the way home, waited for the wife to grab some stuff...)
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Looks like your rig is brush ready :)
Not that it means anything to most people,
the State Of California has made a statement, that the OEM Brake Controller & the Tekonsha P3 are equally acceptable
Random_Walk
Random_Walk
Out
2017 QC 4WD SLT
Pentastar 3.6
I actually have 1-2 in-laws left down/around LA, so I may end up driving into Hel -err, California on occasion. Not going into LA Country with the rig, tho' :)
Magnum Valiant
USA
I installed Prodigy P2 in 2015 Ram 1500 5.7 Hemi about seven years ago and have towed a 2018 Casita Spirit about 10,000 miles. Works great.
Easy installation, plugged into factory towing wiring behind bumper and ran one #10 wire to inside cab.
Considered Ram factory controller, but didn't want the inconvenience and expense. Would've had to take to dealer and pay them for programming, whether or not I installed the controller myself.
rvance
Pent 3.6
I only paid 150 for the factory unit on ebay.
PaulTGarrett
Grumpy old man
Tampa Bay, Florida
408 Cummins Turbo Diesel
I installed the OEM brake controller in my 2012... Was easy... Took me about an hour as I recall, only because I was taking my time so as to not run into problems... I did have to go to the dealer to re-flash the frickin' computer to make it work...
Gr8bawana
6.7 CTD
Looks good nice and level. :party36:
As far as not driving into LA I can't argue with there. I made the mistake of towing out Airstream TT to San Diego years ago and it was a nightmare.
CustomExpress
FL
I added the Mopar tow controller to my 17 1500, and activated it with alpha-obd. I didnt use the inclued bracket, just ziptied it into place in the factory location. No issues :cool:
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
Did the exact same thing (but added some 3m VHB double sided tape to ensure it stays put and doesn't vibrate). Works flawlessly.
But, my Takonsha P3 brake controller worked just as well, before I converted. Was just a problem child to mount where it wasn't fugly.
