Side rail installation
barry hanna
Atlanta, GA
The top rail of the 2013 Ram is plastic. How do I install a side rail in that? Also the front stake pockets are closed, do I just knock the covered section out? My previous Ram 2002 had an all metal top rail so I could install the Putco side rails since the compression washer had something to expand against. But now what? Thanks
Rotzilla
colorado
6.7 CTD
I am fairly sure the plastic bed caps are still the same as my 11. If so cut the front plugs out with a knife, follow the indention.
I was able to make metal contact with 3 out of 4 of the retainers. 1 is against the plastic insert, no problem so far.
Good luck!
quietpeen
2021 TRX
Hellcat
like said above, just cut the front ones out and you will be good
kkreit01
Olathe, KS
You may have to cut round the indented lines in the rear also. Use a sharp carpet knife. Go slow. If you have a tonneau cover, roll it up in case to slip off.
TheM4rxxx
