Side running LED light strip installation help????
LexXxus
Canada
Hi,
I purchased a side running courtesy 70" LED kit from amazon. Manufacturer is OPL5.
I have a 2019 Dodge Ram 1500 Sport with the premium LED headlight package.
It has open wire leads for 1:Courtesy, 2:Signals, 3:Running lights.
Does anyone know if I can tap into wiring harness for the headlights
and get power for, turning, courtesy, and running lights?
If I can do this then what color wires do I need to tap into for:
1:Courtesy Lights
2:Turning Signals.
3: Running lights.
Thank you for your time.
"L
Badger 13
North Idaho
2013 Dodge Ram 1500
I'm not one for tapping into factory wires, but if you do, weather proof connectors should be used. I know this doesn't answer your question, but with the exception of the "courtesy" lights I might consider using the trailer wiring for what you want. You could use fuse taps at the fuse box, or get a T adapter from Kurt for the trailer tow plug and make up a harness from there. Somewhere on this site there was a kit available to have your mirror courtesy lights stay on with the running lights, so that might an option to look at for your wiring as well ?
LexXxus
LexXxus
Canada
I do appreciate the feedback.
I just wanted to get a signal path from each blinker from the front as it's easier to wire up from there to the front sides.
I will however run a relay on each side as to not overload the circuit from the signal path and either blow a fuse or worse.
I will also consider running a custom self made wiring kit from the trailer hitch's signal paths for each side.
The latter of the both sounds more like a safe and stable way to go period.
I have also figured out the signal paths (Which wires) for the blinkers and the running lights from the head light connector plugs.
Cheers,
*L
LexXxus
LexXxus
Canada
I ended up just running a nice quality shielded heavier gauge 4 wire cable ¨zip tie secured¨ from the back trailer hitch plug to the front up into the cab through the floor plug on the passenger side.
I decided to keep all the wiring inside under the dash of the passenger side as there is some extra space there for my needs.
I also fused each connection.
2.88amps on turning signal line each side.
1.44 amps on the courtesy light signal line each side.
Polished Aluminum DiamondBack HD Next!
Cheers,
*L
