bluu09
Hey everyone. Wanted to get your thoughts on side steps. I have a 2018 quad cab 1500. Looking for side steps that are oval, don’t stick out wider than the truck fenders, and tuck up pretty nicely (in other words, are not low and with a large gap between the rocker panel and the top of the step), and black. Like the look of oval bars that have bent ends (roughly 35-45 degrees and not the 90 degree bends). I also prefer the look of seperate step pads for the front and rear doors. I am indifferent to whether they end at the back door or closer to the rear tire though the latter seems a little more useful.
I have looked for the above through multiple sources and companies, but it is hard to tell how much the steps stick out or how low they are when installed. So pics would be awesome.
One last thing, I noticed most have a weight capacity of 350 pounds. Doesn’t seem like much if two adults step on it at the same time. As with most weight capacities, I am sure the stated weight is lower than listed, but feel free to chime in on weight capacities.
Thanks!
Thanks!
