Side step removal problem
RandyGallup
Some of the bolts that hold them on just spin and don’t loosen. They are N Fab brand. Any suggestions?
MADDOG
Living in a Firepit
6.4L HEMI
If you can, get something in behind the bolt head and pry out as you try to loosen them.
Are these in the pinch welds, the body or in the body nutserts? If ya can, post up a pic. I've installed and removed several sets of NFab step bars and maybe I can help if I see a bit more.
RandyGallup
RandyGallup
Sorry but just got back to trying. Got them out but had to grind the bolt heads off. They were the nutsert type. Thanks for the advice..
BWL
Embrace the skeptisism
BC Canada
Had to do the same thing. Couldn't find replacement nutserts so I ground down the old plates and welded new nuts on them to re mount.
mikep345
