Finchr
Hi guys. I noticed my passenger side marker is very dimly lighting up when I press the brake pedal. I am guessing is getting feedback from an insufficient ground at the tail light.
I bought new 3157 bulbs but no change, even flipped them 180deg. I swapped the bulb adapters on the harnesses and no change. If I remove the passenger bulb it stops. I t-tapped the ground tail light ground wire near the bulb adapter and ran a 2nd wire to the chassis ground as a test - no change. I removed and cleaned all the chassis grounds - no change. I don’t see any pinched or corroded wires on the tail lights or headlights.
Cleaned and checked the trailer plug too.
Any ideas what to check next? I am now driving around with my parking lights on so I don’t have the dimly lit bulb when braking.
