cyberwolf
I've had my new-to-me '03 2WD for about a month now. It's only got 50k on it and everything seems to be as it should be. It's been my experience that low mileage, but older vehicles sometimes have unique problems where components are not worn out by mileage, but past their prime due to age.
That said, I have noticed a slight vibration at 65mph plus and am wondering what the best course of action may be. The truck tracks straight regardless of speed, doesn't vibrate when braking, and I don't hear any tell-tale rattles. But it does have a slight vibration at higher speed, sometimes even a slight bounce depending on the road surface, and sometimes a tire hum when turning.
Other threads I've seen lean towards tires as a starting point. The truck has Goodyear Wranglers that are not new, but in good condition and evenly worn. Probably about half tread left. I checked into road force balancing and it looks like that would run around $140. Is it worth it to spend that on older tires, or should I put that money towards a new set? Is there any other area that I should look at first like shocks, tie rods, etc.?
My last pickup was back in the 90s and well worn, and I've only had cars and SUVs since then. So I'm also wondering if my expectations are a little too high...
