sloppy steering on 89 W-150
Supermoose
Minnesota
Best options for steering shaft replacement on 89 W-150?
I just bought it, has been sitting for almost 10 years. I have a lot of slop in steering wheel. When shaking the shaft, under hood, the play seems to be in the steering column above the rag joint. Do I need to replace the steering column or the shaft?
Thanks.
u2slow
BC, Canada
Cummins 6BTA
Can probably put some bearings in the column. Is it tilt? If so, it's actually a GM column and may be easier to get parts for.
PaPitt
Stephenville TEXAS 76401
5.9L
Wow I didn't know the tilts were GM columns .. Amazing how the MFG's did swap in & out a lot of parts .
I was going to say go to wrecking yard & Just find a replacement tilt column & swap it in place.
I Found a Dodge Ram Charger 87 & swapped that column into my 1988 D250 gas Western Hauler flat bed. . I sure like the tilt.
S
Supermoose
Minnesota
Thanks for the replies! It is tilt. I am a big guy so there is not a lot of room in between me and the wheel...LOL! I didn't realize that the tilt columns were GM....will look into bearing replacement. Thanks again!
PaPitt
5.9L
If you already have the Tilt super . Now don't break the tilt Bar or the Tilt Rack & PINION.
wHEN YOU put in bearings & what ever. If you will put up some pictures & Description of how to do I've tried to do 3 FORD 79 TR. & All I've done is ruined all 3.
S
Supermoose
Minnesota
PaPitt, I will do my best to post some pics, once it stops snowing in Northern Minnesota, and I can get out there and wrench on it!
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
look into mopar part numbers : 2265656 and 2925491. that was the column bearing and isolator part number for my 78 d100 column. it also is supposed to work on 84-90 model years.
S
Supermoose
Minnesota
Thanks for the tip!
