So what makes a camera go bad......
Rebelrouser
Cowtown AB
'22 Ram 1500 GT
I've been reading a lot about these Mopar rear camera's stop working and I would like to know what exactly makes them stop working? Mine quit 3 years ago just as I went over my 3yr/60k warranty.What's inside of them that could go wrong so often? I'm just thinking outside the box a little....... Thoughts or any insight?
adurm
FL
2015 RCSB
I would guess moisture or corrosion at a connector.
LB3711
Trumbull, CT
3.6L V6
mine died a few weeks ago. I took the camera out of the handle and found nothing wrong. It flickered once and then it went out. It will be replace with OEM once I find one cheap. About $200 for a new one
snapper23
I am having an intermittent issues with mine,. Sometimes I get a green screen, sometimes I get a static screen. Then it will work. What's up??
Sent from my XT1585 using Tapatalk
baum
savage, mn
2015 Laramie
Has anyone found an aftermarket backup cam that fits in the stock location.
most will fit, sometimes you have to drill the hole a little larger, problem is not all the same connections are used for aftermarket/factory. you would also loose the moving grid lines if you went aftermarket.
Rebelrouser
Rebelrouser
Cowtown AB
'22 Ram 1500 GT
So my other question is do all camera's from '09-present work/fit in the handles? Just curious as I was informed that my camera is indeed toast. Now I'm on the hunt for a new(er) one. Up here they "retail" for $400+!! My wife's cost is $250. I'm pretty sure an OEM one can be bought for less than that-even in Canada or on-line somewhere?
Rebelrouser
Rebelrouser
Cowtown AB
'22 Ram 1500 GT
So riddle me this: What's the difference between '11 to '13 cameras- 2 different part #'s.? I'm finding that '13+ are cheaper than previous years. But do they work/fit the same?
baum
savage, mn
2015 Laramie
could be the connections or they way they communicate to the radio/bcm.
noclass
The connectors are different
