b5rider
- May 21, 2016
- 118
- 17
- 2016
- hemi 5.7
These speakers will seriously change how your stock stereo sounds. Used for @8 months but had to go back to stock. Includes the following:
Focal 6.5 component speaker kit
with tweeters mounted in the window sail panels. Does not have the grilles or the clear covers for the crossovers.
2 6x9 boom mat foam surrounds
Just need to add your amp.
150 shipped to your door (as long as it's in the contiguous US)
If you really need more info, see below or just search for these amazing speakers.
LC6i SOLD!!!
FOCAL COMPONENTS
Coaxial 165mm (6.5″) speakers kit, built-in crossover, rotating tweeter. Grilles NOT included. The 165 AC combines excellent power handling, dynamics, bass quality and good sensitivity. It will also allow direct connection to a High Power car radio.
Specifications
Nominal power 60W
Maximum power 120W
Sensitivity (2,83V/1m) 91dB
Cone Glass fiber
Surround Butyl
Nom. impedance 4 Ohms
DC resistance 3.5 Ohms
VC diameter 25mm 1"
VC height 10mm 03/8"
Former Kapton
Layers 2
Wire Copper
Inductance -
Xmax ± 2.5mm 01/8"
Magnet d x h 85mm x 15mm 31/3 x 09/16"
Magnet weight 380g 0.76 lbs
Flux density 1T
Gap height 5mm 03/16"
Net weight 0.85kg 1.70 lbs
Sent from my SM-N950U using Tapatalk
LC6i SOLD!!!
FOCAL COMPONENTS
Specifications
Nominal power 60W
Maximum power 120W
Cone Glass fiber
Surround Butyl
VC diameter 25mm 1"
Former Kapton
Layers 2
Wire Copper
Inductance -
Xmax ± 2.5mm 01/8"
Flux density 1T
