SOLD
Status
Not open for further replies.
markusaf81
I’ve got Airlift 1000 air bags with everything you need to install. Only thing you will need is two small clips that help hold the line on two of the nipples, if you even need them at all.
When it was on my truck, I used the “T” fitting method so there’s another valve in the box unused.
Also have a set of 2014 Ram 4x4 rear springs, stock.
Airlifts are about $85 new, so I’ll sell for $50 plus shipping. If you buy both the springs and the bags, I’ll do $100 plus shipping. Springs were on my truck for 30k miles, bags were on for maybe 1k mikes.
fire101fighter
South Jersey
Why did you take them out? Any negative affects? Been contemplating these for a while now
JB1
Houston, Texas
What’s the part number on the coil springs and what number was pass side and driver side if different?
What zip are these shipping from?
markusaf81
markusaf81
I ended up just upgrading my springs. I tow a small pop up and didn’t like the sag so I added the air bags and ordered springs. The springs eliminated all the sag so I just never put the bags back in.
Honestly, I think the best solution is timber grove airbags with an onboard compressor. But that’s a huge price difference over airlift bags. Springs are also a good alternative, I think mine were like $220, but again, huge price difference and obviously the stiffer the spring the more ride quality you lose.
If you only tow every once and a while, want to keep your factory ride, and don’t want to spend a bunch of money then airlift 1000’s are your best bet.
Also, no, no negative effects.
markusaf81
markusaf81
I’ll check when I get home. When I swapped springs out I checked and both springs were identical in height and the replacement springs were also identical.
Zip code is 25430
Reactions: JB1
markusaf81
markusaf81
So a few numbers:
71766
05154647aa on one
71766
05154648AA on the other
keith.C.2313
Indiana
2015 Ram 1500 Sport
I'll do $50 if shipping isn't a lot. 46113
Sent from my XT1635-01 using Tapatalk
JB1
Houston, Texas
So a few numbers:
71766
05154647aa on one
71766
Can you determine which side is which by looking at the airbags?......like ok the tee was closer to this one so that’s the driver side etc?
markusaf81
markusaf81
647AA was on the right
markusaf81
markusaf81
Sold
Status
