I have a couple threads on my Dynamat build and video links to tearing down the carrier plate and headliner in the DIY section. Hope they help ya.Hey guys, thanks, this was all the info I was looking for. The tip on the heat is great, Im in FL so that is important. I already have a complete aftermarket system, but I do not like how you can hear the muffled music + slight rattle coming through the doors. Not sure if I am going to do a full install, but those doors must get done and I think that will also make that mid base hit much cleaner. Considering how much work it will be, I think I may just go with the trusted dynamat or other higher end deadener. Much appreciated!
I used raamaudio as well. It works great. It will stay put Just do ur research. The "dynamat" and like products only add weight to a panel to keep it from resonating. Don't waste ur money on 100%coverage either. It's just not needed.
Those doors r the worst for sure. I can't believe they didn't add anything to them. I just had enough to add 2 sheets to 3 doors. To knock on the one with and without is pretty extreme. I really am going to be working on the road noise. I think it can have a really quit cab.
So, I have seen a couple comments already in the various dynamat threads where people are saying there is no need to line the entire door. However, I searched the net to get an understanding of where in the door I should be placing it if not covering the entire door and I cant find anything. Everyone is lining the entire door panel.
I don't have too much of an issue with the sound in the cab as far as rattle goes. What really bothers me is when the music is up and you can hear slight rattle and the music itself from the outside.
I have MT tires, a light bar and roof racks. Needless to say, my truck is loud, so I play the music like Im in the front row of a concert to drown everything out most the time. I don't care to have the car next to me at the stop light listening to muffled music coming out my doors. I'm not concerned about passing on a little bass vibration, that just cant be stopped.
I understand my interior sound will improve, which is great, but my primary objective is to cut out the noise filtering outside. Seems it would make sense to line the entire door. But, nobody is really talking about the sound from the exterior. Will lining the doors give me the solution I am looking for?
He is absolutely right. All the work put into ccf, mlv, and deadner is so u can have an excellent experience INSIDE. Best thing to do if the rattling outside concerns u is play it loud and crawl around the truck and try to isolate certain panels causing the noise. There is no manual that will tell u exactly how it's done.turn the music down at stop lights so the car next to you does not hear your music if it is a concern to you. That's a cheap fix.
Regarding noise filtering outside in general...dampener does nothing for airborne frequencies inside or outside. Dampener simply adds weight to panels to reduce resonances/ vibrations. Technically, it reduces buzzing or eliminates it altogether which is great...but dampener does not block sound. There is a huge difference between sound deadening and sound proofing when it comes to materials used. CCF & MLV with proper decoupling is what reduces airborne frequencies to a degree. You will have more time & money invested in "sound proofing" then you would replacing your mud terrains with something that doesn't howl as much. Sucks, but you can't have your cake and eat it too.
You're not finding a bunch of info regarding sound from the exterior because the volume knob is within reach.
