Speedometer Recalibration
dklozik
Houston, Texas
2021 Laramie 4x4
5.7 Hemi eTorque
I changed stock tires to 275/65/20, so obviously my speedometer was off per GPS, about 5pmh at 70. So, I hooked up the AlfaOdb and just picked the closest tire size to mine that was listed. After the change it was off 2mph at 70. It was late and I didnt feel like going to the process getting the correct size in. Yes, I was being lazy. However, i drove it the next day and my speedometer was now showing dead on with the GPS speed. I got it up to 90 and it was still accurate. Ive read about some people's truck recalibrating on its own, but was skeptical. Mine is a '21 built in mid 2021, if that makes a difference. Is this a '21 thing or is it just sporadic?
retired
montana
was it a stand alone gps or your trucks nav system that you were using?
mtnrider
Georgia
I've Never heard of a truck re-calibrating itself before? My guess is your settings hadn't actually taken yet (sometimes Alfa settings take a key cycle or 2 to take affect). Or your GPS reading wasn't accurate.
D
dklozik
Houston, Texas
2021 Laramie 4x4
5.7 Hemi eTorque
Im using Waze for my GPS speed on my cellphone. Its accurate in my work car and my kids truck, so it should be accurate here.
John Jensen
San Diego County
Ecodiesel
GPS data can vary slightly. Its accuracy depends on how many satellites are connected and in what order they connect. Most devices report the % accuracy.
2mph at 70 is basically dead on. I suspect the dead on reading was due to better satellite connections.
Jimmy07
If you were using Waze via Apple CarPlay while plugged into the media port, then the phone’s native GPS is not being used, and it will mirror the truck’s GPS for speed.
John Jensen
San Diego County
Ecodiesel
I didn't know that. I thought the truck screen was just mirroring the phone's screen and data.
D
dklozik
Houston, Texas
2021 Laramie 4x4
5.7 Hemi eTorque
I was using Waze with Android Auto, but my cellphone was unplugged.
John Jensen
San Diego County
Ecodiesel
I use COOL NIKS GPS Speedometer and Odometer app. Tried several, found this the best for me.
Justin33
I’m gonna try what I’ve read in here I also just put on 275s 275 65 20 duratracs. I can’t seem to find a sweet spot I’ve went aneyehrre from 2672 to 2708mm and the truck is showing 70mph while my phone says 68 with speedometer app? Any ideas guys?
Justin33
Have t been able to get it dead on or is 2mph at 70 acceptable. Truck will read 70 phone says 68.
Justin33
Anyone have a Bette rides what mm I need to try and put it to get this to be perfect. Haven’t been able to hit it yet with what I’ve been trying.
stevenmicheal
