spohn upper and lower control arms
Hemi~D
2014 rcsb black ram edition
My RCSB still has the stock 4 links on it and the e-force supercharger i put on is literally pulling them apart at only 6.5 lbs of boost and I would like to put the spoon upper and lower control arms on but there is brake lines attached to the driver side lower control arm... does anyone relocate these? or just let them hang? Need help any info would be appreciative..!
Hemi~D
Hemi~D
Anyone lol
Booms
The OG
Ocala
2015 Express
Whipple 5.7 • SmoothBoost!
Zip Ties. And do Core 4X4 control arms instead of Spohn. You will thank Me later.
You're welcome. :)
Cut the stock bracket off your OEM arms and weld a couple tabs to it,then I used a couple hose clamps to hold it on my aftermarket Cutter-up arms.That way it's movable if you have to adjust the bars. I agree with Booms,avoid Spohns arms,the Core arms have a good rep.
razor1
St.Petersburg Fl
build your own, go to ballistic fabrication you can order anything you want .
CLOUDL1GHT
Lone Star State
Cummins HO
agreed on just using zip ties.
Go core 4x4. Just ordered a full set for my truck. Way better quality than Spohn
Gary2
S Jersey
My rear Spohns have a bracket for the OE brake line to bolt right on like OE as a matter of fact I think I have them listed in the for sale section adjustable uppers and non adj lowers
Old post. But what's wrong with the Spohns?
Thanks
They've been known to break,as they're made out of thinwall tubing.The Core arms are better quality,as the last thing you want is a locating arm,or panhard bar breaking at highway speeds
BlownGP
Houston/Baton Rouge
Oh damn. I always thought Sphon made good stuff.
Reason I ask, I found a local guy selling a set cheap. Lower, Upper and panhard bar..
Can't believe they would be worse than stock. lol
What about the Freedom Off ones?
The Freedom ones i know nothing about,but from what i've seen guys post about them,they look to be decent quality.I had a set of the Spohn arms and their panhard bar,took them off and replaced with Cutter-up pieces,and the 2 guys that i sold the arms and the panhard bar,both had them break. The panhard bar broke on the guy while he was towing,and the other guy broke the locating arms on a hard launch ,so take it as you will,but i wouldn't run their stuff on my truck
BlownGP
Houston/Baton Rouge
Wow, well I don't want to mess with those then.
Never heard of cutter up brand.
I appreciate the info buddy. Always helping me out.
