fireplug
I have a 2017 Dodge Ram 2500 3/4 ton 4x4 with a 6.4 gas engine. I received a recall notice for something about a D nut on the steering arm that can come loose and cause uncontrollable steering. Dodges answer to this is to weld the nut in place. And every time you need an alignment the nut has to be cut off. Anyone see any problem with this????? At some point after a few welds the arm will need to be replaced. My first question to y’all is what and where is this D nut. There has to be a better fix than this. thanks.
