Help Support Ram Forum by donating:
Steering Column Clicking?
Discussion in 'Tech Info' started by RamIt22, Apr 29, 2012.
  1. RamIt22
    RamIt22 Member
    64
    Feb 2, 2012
    Maryland
    Ram Year:
    Engine:
    My 2012 express just clicked over 5600 miles the other day and when I was driving around yesterday I just started to hear this clicking sound coming from the steering column. Everytime I move the steering wheel even the slightest movement it clicks. Its never done this before. It doesn't seem to be affecting anything mechanically but its really annoying. Has anyone had this problem before?
  2. Cthulhu
    Cthulhu Senior Member
    833
    99
    Oct 13, 2011
    Calgary, AB
    Ram Year:
    2006
    Engine:
    Cummins 5.9
    It kinda sounds like the splines aren't happy.. I noticed this in my 3500 shortly after buying it, that turning the wheel, and going over certain bumps, it made sound, and I could feel it in the wheel. 80,000km later, anything that I noticed back then, has either worked its way out of the truck, or I just don't notice it anymore. I was looking at putting a Borgeson steering shaft in, still might to tighten up the steering a bit, but its on the back burner right now with Child #2 showing up here shortly.
  3. RamIt22
    RamIt22 Member
    64
    Feb 2, 2012
    Maryland
    Ram Year:
    Engine:
    Its nothing I can feel in the wheel though. I drove the truck again today and it was worse then it was yesterday. I talked to a friend thats a mechanic at the dealership I bought it from and he was thinking it might be a clock spring.
  4. JJP71584
    JJP71584 Senior Member
    1,501
    249
    Feb 3, 2012
    Pgh, PA
    Ram Year:
    Engine:
    mine does this too but usually doesn't bother me, curious to see what it is...sub'd!
  5. Joshwaa
    Joshwaa Senior Member
    780
    192
    Feb 14, 2011
    Lake Worth, FL
    Ram Year:
    2016 CC 4x4 Laramie AirRide
    Engine:
    Check your plastics on the back of the steering wheel they maybe rubbing against the plastics on the column.
  6. RamIt22
    RamIt22 Member
    64
    Feb 2, 2012
    Maryland
    Ram Year:
    Engine:
    I am accually picking it up from my dealer when i get off work today. It turned out that it was the clock spring so they replaced that and said im good to go now.
  7. I need to take mine in then. I have the same problem but I have better luck getting new truck then getting mine fixed
  8. RamIt22
    RamIt22 Member
    64
    Feb 2, 2012
    Maryland
    Ram Year:
    Engine:
    I just dropped my truck off at my dealer again today for the same exact problem they just "fixed" hopefully they really fix it this time.
  9. Stu Hanssen
    Stu Hanssen Junior Member
    66
    Sep 16, 2019
    Santa Ynes
    Ram Year:
    Engine:
    5.9 Cummings
    I own from new a 2007 2500 4 X 4 Quad cad diesel that has developed a clicking noise under the steering wheel and I took a wild guess as a 40 year ASE technician to replace the airbag clock spring and it did nothing noise still there. I seems like there is interference in the multi function switch or that area. I am going to use a stethoscope to try to verify this annoying as hell issue as when driving on long straight roads it wont stop!!!
Share This Page
