Dusty
- Jun 6, 2013
- 1,239
- 1,288
- Location
- Rochester, New York
- 2019
- 5.7 Hemi
No warranty on manual clutch systems is not unusual. My '89 Chevrolet had the same warranty exception. And although its not a truck, my daughter's WRX clutch components aren't warranted, either.Something you should consider about dodge and stick shifts.
Read the factory warrantee. In it you will find an addendum for manual transmissions. It says - At no time is the clutch or any clutch components covered under the factory warrantee.
What that means - the clutch, the pressure plate, the flywheel, the pilot bushing, the hydraulic throw out bearing system, the clutch pedal itself are not covered the very moment you take delivery of the vehicle.
If you want a stick, buy anything but dodge unless it is used and already 4 years old.
Regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 70140miles
