Stock 2500 cummins 35 inch tires
Hondo69
Seagoville
6.7 liter
I have a stock 2500 cummins trademans crew cab with 9 inch -12 wheels. If I put 35 will they rub?
Thanks for your help.
mtnrider
Georgia
Probably, it will be real close. The optimal offset for fitment is +18, when you go wider (- offset) they will rub on the fender.
MADDOG
Out Exploring Arizona
A 2.0 - 2.5" spacer lift always worked on my 2500's with a +12 - +18 offset wheel. No rubbing at all.
KKBB
Oakland Ia
My guess is it would rub being a -12 offset...negative offset usually needs a lift or at least a leveling kit.
Dean2
Near Edmonton
Actually depends on the year. The 2021 2500 with 18" tires will take a 35" tire, factory is 33.4", without any rubbing. Also depends on if you have the offroad package or not, offroad is an inch taller. I have the offroad package, they test fit 35" Duratracs, worked fine, problem was we could only get 2, so I went with the stock size because they were available.
Danny Phillips
Payson AZ
My 2015 stock 2500HD came with 20" rims A I just put on a set of Hercules 35/12.5-20 Mud tires and NO rubbing. They're starting to get a little noisy with some mileage on them, but I don't mind a little noise.
