Stock wheel offset
Clancaster23
Uniontown, PA
2021 1500 Bighorn
Anybody happen to know the offset of the stock wheels on my Bighorn is? I'm looking at a new set that has a +1 offset and just curious to know if they will stick out much of any compared to the stocks. Going to use the stock tires for now.
14 Lonestar
If you remove one of your wheels, it should be stamped on the inside.
dlromo
TX
probably +18
MADDOG
Living in a Firepit
17" wheel?
ksn240
Should be a 18.5 mm offset for stock.
C
Clancaster23
Uniontown, PA
2021 1500 Bighorn
Yes mine are 18s. So if the aftermarket are +1 it should stick out a little further than the stock ones do. That's what I want. Thanks.
JB1
Houston, Texas
I’m assuming your new wheels are 9” wide so at +1mm offset they’ll be at approx 5” backspace.
Oem are 18x8 with +19mm so those are approx 5.25” backspace.
With all that....your new ones will only stick out about 1/4” more.
C
Clancaster23
Uniontown, PA
2021 1500 Bighorn
Yep, 5.04" to be exact. That will work for me. I'm planning on swapping the stock tires from the stock wheels to the new ones. The one inch wider wheel shouldn't be a problem, will it?
JB1
Houston, Texas
No you’ll be fine
John813
Has anyone weighed the wheel/tires yet?
stevenmicheal
