Help Support Ram Forum by donating:
  1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Straight piping
Discussion in 'Xtreme Diesel Performance' started by ramthis9501, Jan 16, 2012.
  1. ramthis9501
    ramthis9501 Senior Member
    25
    2,948
    24
    Jul 25, 2010
    Oklahoma
    Ram Year:
    2001
    Engine:
    5.2 V8
    On my dads 06 Ram 2500 with the 5.9, I was wondering if we could straight pipe it ourselves without having to buy an exhaust system. The cat, muffler and other thing in the pic are all clamped on. I was thinking we could just get some pipe to put in the pieces places. Would that work or is there a difference between doing that and a straight piped system?
    Muffler
    [​IMG]
    [​IMG]
    Cat
    [​IMG]
    [​IMG]
    Whatever this is
    [​IMG]
    Thanks in advance
  2. iSlacker816
    iSlacker816 Senior Member
    2,519
    52
    Aug 23, 2011
    Kansas City, MO
    Ram Year:
    2001
    Engine:
    5.9 (360ci) Magnum
    Just cut it out and replace with piping, no difference beside it looks pretty lol
  3. S2kiHemi
    S2kiHemi Senior Member
    3,506
    137
    Jan 15, 2012
    Houston TX
    Ram Year:
    09
    Engine:
  4. ramhunter9
    ramhunter9 Senior Member
    24,508
    953
    Jun 25, 2010
    Ram Year:
    Engine:
    P-Star Jeep Wrangler
    Wrong .. I have straight pipe 5" from turbo to stacks .. thats it . No loss in back pressure at all as in a diesel there is no back pressure as it goes threw a turbo first , you must be thinking on a gasser , then yes back pressure is a issue . You can gut all that crap and just put in pipe .. Or .. get a kit from Jeff at XDP that is a straight pipe kit .
  5. ramthis9501
    25
    2,948
    24
    Jul 25, 2010
    Oklahoma
    Ram Year:
    2001
    Engine:
    5.2 V8
    But thats my question... Is there a difference between the system and just doing it my way?
    And are there any O2 sensors that I would have to worry about.
  6. ramhunter9
    24,508
    953
    Jun 25, 2010
    Ram Year:
    Engine:
    I never had o2 sensors , dont even know if a CTD has them ?
  7. ramthis9501
    25
    2,948
    24
    Jul 25, 2010
    Oklahoma
    Ram Year:
    2001
    Engine:
    5.2 V8
    I don't think it does cause I didn't see any.
  8. BlackedOutHemi
    BlackedOutHemi Senior Member
    26
    5,462
    195
    Feb 27, 2011
    DFW, Texas
    Ram Year:
    2012 & 2012
    Engine:
    5.7L HEMI & 6.7L Cummins
    Crawl under and look. If there's a sensor behind a cat or anything. Then you have to do something about it. If they're all upfront. No worries.
  9. ramhunter9
    24,508
    953
    Jun 25, 2010
    Ram Year:
    Engine:
    There is no UP FRONT ...
    Gasser has two tubes coming off to 2 headers with sensors and BS to the exhaust
    Diesel has one pipe coming off the turbo out the back .
    I am pretty positive there are no o2 sensors on a CTD
  10. Stangshcky12
    Stangshcky12 Super Moderator Staff Member Super Moderator
    9,063
    896
    Oct 26, 2011
    Oshkosh, WI
    Ram Year:
    Engine:
    5.9 Cummins
    Your turbo creates all the back pressure your truck will need, anything after that is just resistance
    The stock system is 4" which flows enough for up to 500 hp. If your planning to go more, go with a 5".
    There is nothing else there but a cat, muffler and resonator.
    On my girlfriends 05 I tried just unclamping and disassembling but no dice. Between rust and the exhaust temperatures they wouldnt budge. I even sprayed it with pb every day for 2 weeks.
    I do beleive the cat has an offset from in to out so you may not be able to just weld a straight piece of pipe in. I've been meaning to check. You could always use a short piece of flex pipe for the cat and just 4" for the muffler and resonator
Share This Page
