Reception is great, I haven't noticed any change.
To get the ball end off, use some pliers and kinda work it back and forth while using a twisting motion, it's a press fit. Then I just determined the length I wanted, placed it in a vise and cut it with a common hacksaw. Next I sanded it down with sandpaper. Next I used a file to remove any burrs where i cut it and kinda file it to a taper, during the filing I would test to see if the ball would go on the end. Keep filing until you can twist it on with force. Then I just spray painted it semi flat black. I like it because it looks unmodified and performs as oem
