Stuck lower front strut bolt
jonj200369
06, 1500, 4x4, 5.7
Broke the front, drivers side lower strut mount..... I have the bolt half way out and it is extremely hard to remove. I was using a ratchet with a breaker bar and i'm pretty sure if I crank on it anymore its going to break. Any ideas? images attached
smoothee
St. John's, NL
I'd try soaking it with PB Blaster for a bit first if you haven't already. Maybe hit it with a little heat. Have you tried tapping with a hammer to see if it moves at all. I recently had to cut both my lower strut bolts out and replace the bushing on each side, the sleeve in the bushing was seized solid to the bolt. It's a fairly common issue, apparently.
charonblk07
Calgary, Ab
F1-A forged 349ci
There is a lot of rust that builds up inside. Since the bolt's moved that much already you can hit it with a hammer and it will move through and once it's flush with the fork use an extension to knock it through all the way. The shock can also be causing the bolt to bind so you might need to lift up on the control arm but more likely it will need to be pried down with a bar to unload the fork entirely.
justin13703
MD
I had this same problem with mine and had to cut them out. I guess Chrysler doesn't believe in anti seize lol
GoldDot
Spray it with rust penetrant every day for 2 weeks. Thats if you have the time of course.
usaf2006
Augusta, GA
Slam it outta there, and if it won't budge, cut it out. RockAuto sells a new bolt and bushing kit for a little over $20 made by Monroe. If you are able to reuse them, coat that beast in antiseize before it goes back in.
xb1230
Hobby Mechanic
South Shore of Montreal, QC, Canada
I have removed bolts that were rusted in place using an open wrench big enough to slide right behind the bolt head and tapping on the wrench using the bolt's head for leverage.
In this case I am not quite sure you have enough space for that.
If the bolt and bushing are available for 20$ unless you are on a really really tight budget I would not worry, cut it out and replace it with a new one. As mentioned above be sure to butter up the new one with a generous amount of anti-seize (copper based ones are even better) when re-assembling.
Hope this helps
Joe.G
2004 SLT Quad Cab Short Bed
I would try and unload the pressure off the bolt by prying it up or down, Then I would beat it with a hammer and it should pop out, I would not reuse the bolt since you say it feels like it is about to snap, there is a chance you weakened it and its just not worth it.
ChrisRoden
Nova Scotia Canada
They say to unload the pressure on bolt by using pry bar on lower control arm and work the bolt in and out untill gets to hard to turn spray with your penetrant over and over as it get to hard to turn and it will eventually release and pop out
Judy
Midwest
Hubby said to spray penetrating oil on it and screw it back and out repetitively.......
now you guys see why I like these issues.......mmmmmm!
bellaireroad
Fort Worth
06, 1500, 4x4, 5.7
Heat is your friend
