Suddenly stopped won’t fire back up
H
hfaber329
Southern Maryland
1989 d100
Basically you have an LA318......Check the distributor. Make sure the Rotor Bug's tip did not break off inside the cap. See if the condenser has failed. If you have a single Coil, see if it has failed. Pull a plug wire off and see if your getting fire (i'd do that to all 8 cylinders)
Thanks for the advice Jeff. I discovered it was a melted harness against the new headers and was shorting the injectors. Also the distributor cap was in need of replacing.
amdwilsns01
