hfaber329
- Aug 13, 2020
- 17
- 3
- Location
- Southern Maryland
- 1989 d100
- 5.2
Basically you have an LA318......Check the distributor. Make sure the Rotor Bug's tip did not break off inside the cap. See if the condenser has failed. If you have a single Coil, see if it has failed. Pull a plug wire off and see if your getting fire (i'd do that to all 8 cylinders)
Thanks for the advice Jeff. I discovered it was a melted harness against the new headers and was shorting the injectors. Also the distributor cap was in need of replacing.
