Tune Time Performance in Lakewood, NJ is the tuner and engine builder. Frustration aside, from the delays, part mfg issues and other crap, they did follow through on their promise, and that is we/they stand behind their work and will make it right. They rebuilt the motor (twice) on their dime. Not many shops would do that so my hat is off to Matt and the whole team at TTP.
Now - still have some drivability issues going on but overall it runs extremely strong. ECM still crashes randomly so we have another ECM on order from HP Tuners. For whatever reason the ECM loses communication with the truck and things start failing (ABS brakes, transmission, suspension, etc) which triggers lost communication codes. We looked at all the connections we can (fuse panel, box, ecm, harness, etc) and things are good. This issue started back in February/March when we first got the unlocked ECM back from HP Tuners. So - we are hoping this solves it because we are at a loss to why its happening. They've had bad unlocked ECM's in the past so it is plausible. Will find out next week.
Gone - I appreciate your offer to take a look at the tune but out of respect of my tuning guy I'd prefer not bringing anyone else into the mix.
Not sure if you read all the posts but the o-ring issue was not because of the tune. Valve retainers manufactured by Comp Cams failed which dropped a valve followed by pieces of the valve being pushed into the intake forcing up the fuel injector and bending the fuel rail exposing the o-ring causing the fuel leak.
Its fast and seems to pull harder once the RPMs get into the CAM's sweet spot. WOT throttle tuning is not completely done yet. Scheduled for next week along with Dyno. Waiting for the new ECM. Until then I'm driving and logging stuff for the tuner.
Here is a slow roll into full throttle uphill on an on-ramp, and then a fuel cut-off at 105mph. LOL
