suspension problems
srt2slow
fort dix
viper v-10
hey guys..quick question.... for a couple of months now its been scary to drive my truck at highway speeds...when u change lanes the back end seems very lose...my rear suspension consist of a rear flip kit, caltracs , 9 way adj shocks, rear sway bar and air leveling kit....everything is pretty new..they oonly thing i can think of is the rear shocks...anything else i can check for....thanks
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
What do you mean by the back end feels loose? Leafs dont really go bad or wear out, and the caltracs and swaybar should help keep the rear end planted. Have you tried adjusting your shocks to a stiffer/softer setting yet?
dogcar3
2012 Power Wagon
Have you checked your tire pressures?
S
srt2slow
fort dix
viper v-10
i tried different setting on the shocks ...nothing..
tire pressure is correct
and the spring perch is welded
i really think its the shocks...i took them off to test them....they are kind of easy to compress but are a ***** to pull out on the number 9 setting...
S
srt2slow
fort dix
viper v-10
any ideas....i still have this problem....i just bought a set of qa1 shocks and still the same thing....took out the caltracts , nothing ......its driving me nuts.....
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Sounds like it may be the tires. What brand and size are they, and how many miles are on them? I would try to rotate them to see if the problem is still there. Also, check your air pressure.
S
srt2slow
fort dix
viper v-10
brand new stock size nittos....they have about 4000 miles on them...i will recheck the pressure now
TheMaddog
DFW
is it making a noise? i thought mine was loose, but it turned out to be my spare tire is hanging down too low.
Stangshcky12
Oshkosh, WI
5.9 Cummins
Probably wouldnt hurt to make sure the sway bar is tightened up as well
S
srt2slow
fort dix
viper v-10
just checked the pressure....its 38psi all around....thats what its supposed to be....
the spare is not loose
by loose i mean at highway speeds the back end is not tight when i change lanes...the front is very responsive but the rear is not...
i just took everything off and re torque to spec and its still the same...
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Did you change anything just before you noticed this? Did it start right after adding the new tires?
S
srt2slow
fort dix
viper v-10
i did the caltracts and tires the same day....
icywhite
are you sure its in your rear.... could it be something like ball joints starting go out giving you a sway as you change lanes?
S
srt2slow
fort dix
viper v-10
Fixed it.....one of my shocks up front was done....I put a matching set of qa1's in the front now...and they sent me the wrong back plates for my caltracs...she's back to normal....handles 100 times better with qa1 all around....just waiting on my swaybars to come in...thanks for all the help guys....
