Brubaker
- Mar 9, 2019
- 1
- 0
- Location
- Central Western Michigan
- 1994
- 12 valve cummins
First will the dash assembly bolt up from the 1994 to the 2001??? Next question what is the difference of the frame rails with the same wheel base 2-wheel drive 1994 2500/ 2-wheel drive 2001 1500 . Our story here is we have a 1994 12 valve cummins 2-wheel drive. 5 speed stick that the Michigan winters here has taken its toll on the frame and body. We have located a southern rust free 2001- 1500 2 wheel drive with the same wheel base . We would like to use from the donor 1994 the dash cluster all wiring harness , motor , transmission, front and rear suspension , drive-lines, radiator and air to air after cooler. is this a near bolt in process?? minus the riveted parts of the suspension???
