Sway bar kit
lftd17
Pueblo Colorado
Just lifted my 2017 Ram 1500 with a RC 6” lift. Lifted struts and upgraded rear shocks and springs. It rides great but I want to reduce my body roll and I’m looking for a full front and rear sway bar kit….but can’t find one. Anyone have any input on this or another way to stiffen up the ride?
Administrator
With a 6" lift you'll probably need to buy separate end-links for the sway bars. Then just use Hellwig sway bars
crazykid1994
4wd there is no aftermarket front sway bar option currently. Hellwig has a rear bar option that as far as I know is pretty much the same as the upgraded factory bar except it has adjustable stiffness options. What tires do you have and what psi are you running on them because that will play a big role too especially at 6” lift
L
lftd17
Pueblo Colorado
I’m running 22x12s wrapped in 35s at about 50psi
crazykid1994
What is the exact tire though. If you run your psi to high you can get a bouncy feel. However, look into the hellwig rear bar for your truck
L
lftd17
Pueblo Colorado
They’re 35x12.50x22 Arroyo tamarock m/t. I’m looking into the hellwigs just trying to find a good set of bushings.
DILLIGAF
Canada
Get a Hellwig and Clayton Offroad 4 link and for the front ditch those garbage end link extension for Suspension MAXX.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Hellwig
