Tachometer Red Line?
jpaskell
Phoenix
Not sure this is the correct place to ask this question, but here goes.
I note that the Tachometer on my 2013 RAM does not have a "Red Line" . Is this correct? Do we not need to know the "Danger Zone"? Especially when towing up mountain roads.
If this question seems like a dumb one, I am new to the RAM family.
Thanks,
Jim
Neil E
Morganton, NC 28655
my 17 with the 3.6 doesn't "show" one either. But it's 6500 in my wife's Challenger, I believe it is the same (assuming it's the 3.6).
TheEnder
4.7L V8
Thanks,
Jim
3.6L Pentastar V6: 6500 RPM
4.7L Powertech V8: 5500 RPM
5.7L HEMI V8: 5500 RPM
Your tachometer is normal. If i recall correctly in late 2011-E2012 there were leaks of the prototype 7” cluster that looked far different than the ones in 2013+ trucks, with redline, etc.
Sent from Blue Onyx
For the most part the ECM/TCM will keep the engine from over-reving unless you force downshift too much headed down a mountain and let it get away from you.
BadHemi2014
Greater Cincinnati area
Welcome!
And actually good question. I've had my truck (2014 5.7) since October and just this past week realized there was no redline on the tach.
RedSRT4Me
Scottsdale, Az
2015 CC Sport
Sent from Blue Onyx
And here is a pic of the 7" display Ender is referring to. Unfortunately there isn't a redline indicated on mine either. Truck is 2015.20200708_093649.jpg
Pull Ya
Cedar Creek, Tx
Anything over 6200 and you're asking for trouble unless you have done some internal engine work. To be safe and for longevity, I'd stay under 6000.
Jay
ChevySlayer69
Maine
I got hemifever trans tuning and raised shift pint to 6100/6200... Made a pretty big difference. The default rev limiter for the engine was set at 6800 in the pcm (engine) tune.
NJMOPAR
Older and faster
ELizabeth, NJ
My 2010 has no red line either.
I set my rev limiter at stock+500 with my Flashpaq tuner.
Mike Townsend
Most trucks that I have seen have not had an indicated red line in decades. The first one I saw without one was in my parent 1997 F150. Not sure why it is a truck thing.
@Mike Townsend the diesel powered trucks have the redline marks on the tachometer. The EcoDiesel is 4500, the Cummins is 3500 and if I remember correctly the dashes will work in either if someone is looking at upgrading to a premium cluster.
If I had to guess why they stopped putting the redline marks on the gasser tachs, is it scares some people to run close to redline when towing. The engine needs to run up there for the torque and will hold together just fine.
2012RAM1500RT
NC
Back in the day if my vehicle didn't have a tach I'd buy the Sun tach we use to get and I'd wind the engine until the valves floated and would set the red needle that came on them (you could set yourself) 100 RPM before that and that's where I would speed shift to the next gear.
