13HD3500
- Jan 15, 2020
- 19
- 2
- Location
- CBS, NL, Canada
- 2013
- 6.7 Cummins
2013 3500 dually, I've got a right rear signal and brake light out. Taillight works and reverse light works. Did the usual, swapped bulbs and even swapped sockets. All work on the driver's side, I'm guessing I'm down to a broken wire somewhere along the chassis but upon further inspection between the trailer harnesses and the main harness it's quite a jumble of wires under there.
Is there any common place to check for a broken wire? I still have taillight, just no brake/signal so I'm assuming they are both on the same wire?
What color wire is for what? And would I be safe to just run another wire instead and tap into the back of the socket? Was thinking the easiest route was to the trailer harness but I'm thinking that's on a different circuit, I'd still like for the lights to work and the message in dash to go away as well LOL
