Tail Tint
HemiBabe
DFW
Looks really good!!
Sent from my Android.
quietpeen
2021 TRX
Hellcat
to keep the pain from peeling with the take take xacto blade and carefully trace the outside edge of the tape.
Musclemckeester
Houston, TX
n/a
n/a
Those look really good. So did you end up with 3 coats?
On mine the tape came off really easily, I just took it slow and watched it.
T
truckin151
2013 sport
Did 2 coats, took a razor blade and picked a corner and slowly peeled it off. I think they look real good. Going to do a wetsand here in an hour or 2 (give it about 4hrs of dry time, then clear it and let it dry overnight.
Here is where Im at now
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Looks good! Did you take em in the sunlight to see what they looked like?
T
truckin151
2013 sport
Not yet, it was raining outside by the time I had everything done. They are not blacked out though, you can still see the red shining through which is what I was after.
T
truckin151
2013 sport
Oh and the blue you see on the clear parts of the lights is the tape coming through from the back.
blackout11
alpharetts GA
2011 R/T
Id put like 3-4 coats of clear then let dry for few hours wet sand then compound them they should come out like glass.
T
truckin151
2013 sport
They need a wetsand before the clear goes on, there are a few imperfections in the paint that you can feel.
blackout11
alpharetts GA
2011 R/T
so the compound gets rid of the wetsanding effects?
Yes you wet sand the vht then put on the clear then wet sand the clear after it dries and the compound makes it look like new/same thing they do to a car once its painted they wet(colorsand) it then buff it with compound
T
truckin151
2013 sport
Second round of wet sanding done, clear will go on in the morning
Im reallly liking how they turned out, they are dark when not in direct light, and a dark ruby color when the light hits them just right.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Looks good, I have been thinking about doing this to mine too.
blackout11
alpharetts GA
2011 R/T
Yep few coats of clear a wet sand then compound they will look like you bought them tinted.
T
truckin151
2013 sport
Clear coat is going on now. God they look good
T
truckin151
2013 sport
5 coats of clear
Just got to wait for them to dry for the final wet sand and polish
RAM-it83
