Tailgate LED Light Bars...do the mess with towing package?
VA-RAM
STL, MO - Norfolk, VA
2017 Laramie / 2020 Laramie
If your running the OPT7 tailgate led on a newer Ford, 8t My very well trigger the system for towing errors. There is a module you can get from OPT7 that will fix that. On Amazon
jeffawats
thompsontown pa
Was just looking at doing the OPT7 triple they also told me I needed the module for the backup camera.Which length are you guys running 48" or 60"?
RocketFoot
RocketFoot
Southwestern PA
I got the 60" as well...fit perfectly. I didn't use the module on my 2013 but you may need it if you have back up sensors or anything like that.
Steelheader99
Crescent City
2019 2500 Laramie Sport
Hammer22801
Louisiana
Just installed my opt 7 60” light bar on my 19 classic with sensors and back up camera.
removed the spare tire grommet, used curt adapter, used the 4 clamps that came with light and some gorilla double sided tape on the ends of bar, connected white reverse wire to a bullet adapter and plugged into the 5th hole in the curt adapter. Zip tied wiring to undercarriage of my truck.
light works like a charm and the reverse light is bright
