Rick Ram-jet
- Feb 8, 2018
- 211
- 189
- Location
- Big Bear Lake Ca
- 2016 2500 4x4 CC / LB
- 6.4 L
Unlike most of the group my PW has only been in the snow once. It's one of the downfalls of living in SoCal. Thus my post may not be relevant. I just switched to Falken AT3's 12.5X 35 X 17. My experience so far is uneven road surfaces are magnified, any type of grove pulls the truck more than on stock tires. Stopping, well the brakes seem under powered with the larger tires. I really noticed it when pulling a trailer. Before you ask yes the trailer also has brakes and only weighs #3500. The good is no rubbing, but I have Thuren 1 1/2 inch over front springs and Fox shocks. A much better look the stock tire as small for the big size of the truck and a 55,000 mile warranty. My 2 cents is 35's are good I would worry about stopping power and acceleration with 37's.
You are correct about 35`s vs 37`s, you wont "feel" the 35`s too much, the 37`s are much more noticeable due to increased dia/weight. After awhile the 37`s feel normal to me, however, I will probably buy a set of 35`s for towing....
Also, try dropping your air pressures (start around 50psi and do the chalk test) when not towing, it should improve your ride.
