Tanny fluid
Jeff Krawczyk
Massachusetts
Looking for suggestions as I went under my truck and noticed the output shaft seal with a leak and tranny fluid has obviously leaked out as it was sprayed around from drive shaft, well I'm going to replace seal today what's the best way and best fluid to use, I dont want to go broke with buying fluid but do t want to use garbage either....thanks
It's a 2014 bighorn 5.7
Jeff Krawczyk
Jeff Krawczyk
Massachusetts
Has anyone used redline....looked in the interwebs and that was one that came up and says it works with the rams tranny
waynestractor
Vancouver Island
I had a 13 with the 8 speed it was a Bighorn model
That was the first year the 8sp was available I believe. I was hoping to find a '13 Laramie with the 6sp when I bought my '10 as I much prefer the console shift over the knob. Now I know I can look for a '14 with a 6sp.
In that case I would stick with either the Mopar 8&9 or the ZF Lifeguard fluid. ZF has some pretty strict specs for their trans...
There are several really high mileage EcoDs that have been changing the 8 sod trans fluid using Valvoline MaxLife trans fluid at 100K mile intervals with no issues. The one that stands out the most is over 600K miles and tows travel trailers for a living with his.
Hemi395
Cape Cod MA
Wow 600k and still on the original motor and trans? Did they leave the fluid heater on or bypass it?
Sent from my SM-T320 using Tapatalk
Burla
2010 Hemi Reg Cab 4x4
So the reason why they use PAO oils because they choose a very thin oil and they don't want it shearing down over time. That's a fact. Redline d6 would be the proper redline if you chose that, and would fit the bill for their spec.
So atf 4's maxlife and others, do not meet the spec as far as starting viscosity, but they work as sean on eco diesel proved. Which would be redline c+ as a comparable product to maxlife.
Changing fluids and level is such a pita with the 8 speed, I might go higher quality fluids and change less often. Now sean changed his fluid very often, in which case maxlife worked perfect, who knows maybe it would work even with a long oci, dunno. I know if you are in a snow state, redline d6 will give you pao oem quality at a fraction of the cost of oem. The oem spec is a real good idea in cold places, that maxlife would be plenty thicker at start up then redline d6 or oem pao z8 fluid.
RVGuy
Alberta, Canada
My '15 has a 6sp, I've seen '19s on lots with the 6sp but they're SXT models.
I'm guessing the 6sp will be a thing of the past officially once they stop making the "Classics" but until then the SXT and SXT plus model still comes with it.
The original motor lifted a head gasket around 371K, dropped a new complete motor in and is still goin. Transmission is original and as far as I know uses the stock transmission TMU. Not sure exactly when he started running a transmission tune but it I think it was well after the engine swap.
waynestractor
Vancouver Island
Is that in 1500 or 2500's, or both?
Canada is FCA's dumping ground for the older 6 speeds.Airdrie Dodge just north of Calgary had a couple 2019 Express's sitting on their lot with the 6 speed in them a few weeks ago,haven't toured through their lot in a bit to see if they still have them though.
RVGuy
Alberta, Canada
I can ask, my father-in-law is a salesperson there. I've seen them in a few of the Edmonton lots too. Express, SXT, and SXT Plus all still come with the 6 speed, he was saying they've been selling a lot of the SXT Plus models lately.
waynestractor
Vancouver Island
Good to know. I was looking at their website but can't see if the console shifter is an option in any of them. I prefer the 6spd as I hate the knob. My 2010 has 150,000km and no issues at all with the tranny.
