To activate it with the tailgate is a bit tough but another option would be to tap into the cargo lights and run a switch in parrallel from a constant 12v so they would come on with the cargo lights or with the switch
So if you tapped into the cargo light wire but also put a switch to constant 12v, like mentioned earlier, would the lights come on with the cargo lights when the switch is in the off position? But you'd be able to turn them on with the switch regardless of the cargo light?
