Taser Audio/Video install?
Gixxer750
N. Idaho
2015_2017
This is pretty cool. Check this out...
Has anyone installed the taser audio video cable to screen mirror there phone for YouTube or what-have-you? From what I'm seeing you can simply take some RCA cables and use the 2 wires (+/-) for each RCA cable and using open pinouts on the back of the Uconnect 8.4, install an aux RCA that you could plug a video source into.
They made it seem as if you had to have the Taser setup in order for this to work, but I feel like after watching this video I could do this with stuff I have laying around the house and MAYBE alpha obd if taser is actually necessary.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
You are right, you can DIY for much less...
https://r.tapatalk.com/shareLink/to...&share_fid=17770&share_type=t&link_source=app
RAMTRPR
"Enjoy The Little Things"
Brentwood, CA
Do you need the 8.4 for this or can this be done with the older NAV units?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
Not sure I understand your question. What year truck do you have?
