Anyone complete the install of the bi-pass module, I attempted per the instructions "for previous models".
My 19 looks different behind the radio?
I gave up, really didn't like pulling the radio-trim bezel apart and the thought of doing that again if it needs to be removed prior to a dealer trip.
Report back on your results if you would.
I'm thinking about getting a Tazer. Were you able to install yours ? Are you happy with it ? Were you able to access everything just by removing the panel just above the Parking Brake ? Thanks. Any help is appreciated.For the 2019's you don't have to mess with the radio, pulling the center stack etc. Specifically for the 2019's all of the wiring for the bypass is done above and to the side of the parking brake. I believe you have to remove the panel just above the parking brake to gain access:
http://www.zautomotive.com/zpu/instructions/2019-Ram-Bypass-Install.pdf
