Reuben
- Sep 30, 2018
- 170
- 164
- Location
- Eagle, Colorado
- 2018
- 6.4 Hemi
I have a few questions:
Have you tried the "Fully disable ESP/Traction Control" function? Can you disable everything but ABS?
If you disable Tire Pressure Monitoring System warnings, can you still see you tire pressures on the EVIC dash display?
Is this the cable needed to add a front camera?
https://zautomotive.com/product/video-cable/
Thanks.
You can kill the TC but you have to keep it plugged into the OBD port.
You still have to bring it to the dealer for the psi to be “set” otherwise you will still get the dings. Or you can shut the tpms off completely which will shut off the dings.
I’m not sure when they will get to the locker functions. Have yet to hear back from them. If you just want the basics, the procal is the better value as far as aftermarket programmers.
I bought a camera but haven’t got around to gathering the other parts. I did activate the cargo camera so when I’m ready it wil be done.
