JJK
- Mar 4, 2015
- 122
- 22
- Location
- Minnesota
- 2016
- Sport quad 4X4 HEMI 5.7
Please help get this figured out!! 2014 1500 5.7 Hemi Mods: ARH LT with 3" mid pipe 24"magna flow mufflex, 87mm Tb, S&B, Diablo dcx tuner running custom Hemifever tune 91 octane tune and a catch can witch really isn't a mod
emoticon Here the issue When i change tunes at the end of the write on my evic it says service throttle body (Big and bold) and that comes up the first time you have to cycle the key to off at the end of the write. Then goes away! I put the stock Tb back on the truck and ran it for a few days does the same thing. I also get the icon when i push the start button.And also at that point get service 4WD light witch blinks and goes away also. Like it's running a test? go into the tuner and there is no DTC codes ever! The truck runs good. It's been going on for month or so. Checked wiring and both TB's are spot less. Any ideas before i take it to the dealer!! Thanks in advance for the feed back.
