RainDodger
Hi, guys... I'm a first-time-RAM owner of a 2019 1500 Classic. There's a lot of talk about the ECO light and how to make it go away or stay away or not go away, or whatever. There's a bazillion mentions of it. I apologize if this has been mentioned. My truck has the 8-speed ZF transmission and I don't know who this would apply to... but here's what I found, and I don't see a down-side to running this way occasionally:
Once you’re moving and not in Park, hit the Gear- button. It will come on in any given gear, depending on your speed. Adjust it so that you have 8th gear selected.
Of course that selection means that the transmission is going to work perfectly normally but cannot shift into a higher gear than 8th… of course it can’t, because there aren’t any gears above 8th!
The ECO light will never come on. If it was on when you selected any gear with the Gear- or Gear+ button, it would have gone out. Once you go into Park, the truck will shift back into the regular Drive mode and ECO will be back on.
Everything shifts normally from zero to any speed, as far as I can tell. Shift points are just fine and it downshifts normally when you accelerate. I think it’s all good. No more throttle mushiness when driving around town and it keeps going into ECO mode. I found that irritating.
Once again, I apologize if this is ancient information. Anyone think there's a problem doing this?
