I think their is a way to re-calibrate the system ,you would have to goggle itNew 2020 1500, the outside thermometer reading is erratic, often around 10* off,
sometimes close enough within 2*.
Any others with this issue ?
Mine is way off always on initial startup...think it is because it is in the sun and heats up the surrounding area where the sensor is (since it is black most likely). Takes a few minutes of driving to get the reading to become accurate.
I pretty much know the temperature before I get to the truck. Just a gadget with little relevance to me.
Not connected. The autoclimate control has its own thermostat inside the truck.It matters if you have hvac set to automatic as it will blow the AC MAX for a LONG time as it is usually 10+ degrees off to the high side.
There is this little thing that runs around the truck call the CANbus that transfers data from modules all over the vehicle, like the door modules that the OAT plugs into. It's even shown on the CANbus connection on the wiring diagram. The HVAC system can be affected by the sensor not reading and it causes a CEL.
