Dusty
- Jun 6, 2013
- 1,239
- 1,285
- Location
- Rochester, New York
- 2019
- 5.7 Hemi
I hope that helps with the problem.No I didn't know that , thanks! I'll try it. I picked up a code scanner and am getting 5 ABS codes and 2 SRS codes. I did put the old TIPM back in since that wasn't the original problem. I had also removed the Brake light relay in the fender well and re-installed it. The codes I'm getting are: SRS-U1414-00, U1415-OO; ABS-C-1000, UD102,C2206,C1090, and U0141.. i'll try your suggestion and see if it helps.
Also, you need to be careful with used TIPMs. I've been told that there are often more than one type used even in the same model year and some require a flash. Not sure what the differences are or why.
Hope you solve the problem soon.
Best regards,
Dusty
2019 Ram 1500 Billet Silver Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 3 June 2018. Now at 72444 miles
