- Nov 2, 2020
- 10,137
- 12,775
- Location
- El Cajon Calif. 92021
- 2016
- 3.0 ecodiesel
The Ram alarm does not work if you go in through the sliding window
You can quickly drill up through the drivers front inner fender & right up into the battery shorting it out & then you can completely strip the Ram of anything or everything within 10 minutes if you have a good team & you are good at it
Spraying Freon into The Clubs lock & hitting it with a hammer will shatter the locking mechanism
You can also use a cordless drill & titanium bit to drill out the lock
If your worried about someone stealing your vehicle, hide a cut off switch that kills the fuel pump
Don't sweat things, 25 year olds with gray hair look strange
